Anyone else having trouble logging into their controller today?
It was working perfect yesterday. Today I can not get the log in process to complete. It is stuck at the spinning wheel of boredom just before I can normally see the UI.
I tried to log into the device locally and it does not accept my user name and password.
Any help is appreciated as Vera is not returning calls nor taking them.
I can login locally just fine, but remotely is total failure. Tried with imperihome on local network = success. Switch of wifi to 4G and nothing. Local computer logs into vera just fine. Laptop remotely = fail.
Locally it is the same user name and password we use to log into the gateway?
I would think it is my unit only but maybe since you are having problems remotely also, maybe not.
I would think it is my unit only but maybe since you are having problems remotely also, maybe not.[/quote]
Same here, ive been communicating with MCV today and they indicate its not on their end. Local is fine, remote via web or app - no go. I have similar issues as others here. UI7 - 1.7.1419
the status.getvera.com website shows no known problems so I’m not sure what’s going on. I was connected through AuthomationHD via the WAN most of the day keeping an eye on my dogs…
I had issues all day as well, pissed me off since I couldn’t disarm the house after I came home, I had to listen to the alarms until I could log in locally.
robertgabrialson, thanks for pinging me on Twitter. You were the second report that I received today. What ever is going on is highly isolated. When both Robert and the other Twitter follower posted, we did login tests from NJ and CA without issue. I am working with Customer Care and the Networking Team to identify what might be going on.
Working now in So Cal!
I still can not log in locally. I do not have it secure. I am using the same user name and password I use for logging into the gateway.
Is that correct?
My whole system seems bricked for no apparent reason. Was working fine this AM…I added a few new scenes to my Leviton 4 button zone controller, then let to get lunch…
Came home, and I’ve got a blinking status light, Z-wave light out, and solid Power, Internet, and Wi-fi…Nothing works. It’s dead. Can’t log-in remotely or directly. Reset button doesn’t seem to work either as we end up in the same spot…
[quote=“ciro307, post:19, topic:188893”]Haven’t been able to login for two days.
I down loaded Stacks, installed Home Buddy on the PC.
Good to go![/quote]
I was that you have spoken to Customer Care. Is everything working OK now?
