Anybody has set up Ezlo with Homebridge?
I have home bridge + homebridge-vera plugin working well with my Vera Plus. After the upgrade to Ezlo recently, I have problem get the homebridge working: It seems the API interface of VeraIP:3480 stopped working:
Unhandled rejection RequestError: Error: connect ECONNREFUSED 192.168.1.60:3480
I’m wondering if anybody has seen and fixed this issue. Better yet, has there been any “official” HomeKit support for Ezlo released yet? Thank you very much!
Greetings, Hamania
Unfortunately, there is no Homebridge integration for Ezlo so far, so that is the reason why you can’t get it configured
But don’t worry, we are getting the integration request submitted, so our Team can work on this too.
You can check the integration request here:
https://jira.mios.com/servicedesk/customer/portal/72/ECS-1232
If you wish to make additional comments, you are welcome to do so.
That same API / Port does not exist on an Ezlo Controller. As its a totally different API on the new Ezlo controllers. So all previous integrations with the old Vera hubs will no longer work on an Ezlo hub. Likewise for any plugins on the Vera hub they do not work on an Ezlo hub.
