Just started putting my Vera system together today. I’m starting with a basic layout.
I installed the following without a hitch and everything is functioning great:
12 - GE 45612 Dimmers
3 - GE 45614 3 Way Kits
2 - Jasco 1P Switches 45609WB
2 - Schlage BE469
Has anyone had any luck with finding a ZWAVE dimmer that can handle a low load of say 20W? The GE Dimmers are dimming my CREE LED Retrokits in my recessed lighting just fine. Except for when the load is less than 40W. I played around with the loads a bit and added two circuits together to ensure I’d hit the 40W’s. But in the kitchen I have 3 dimmers with 20W each on them. Currently with the GE Dimmers all you can do is turn them on and off or they will flicker like crazy.
Yours is a common issue with LEDs and dimmers that do not utilize a neutral wire, like your GE/Jasco dimmers.
I have had good luck with Cree bulbs and Linear WD500Z Dimmer / Evolve LRM-AS Dimmer which require a neutral wire. Though they worked fine at first, I have had a couple of these bulbs develop a near imperceptible flicker at very low dim levels(under 15%). I returned these and the replacements are good, so far, with some operating at as low as 2% dim level. However at these low dim levels, they are susceptible to line noise and sudden load changes on the line. Things like fans going on and off will cause a momentary/single flicker(near instantaneous flash).
The other way around the flicker issue, when using dimmers that do not utilize a neutral, is to add a dummy load to the circuit. Search the forums, there are countless discussions of copious length about this method.
Thank you. I think I’m going to attempt to return the GE’s to Amazon and see if they will take them back. I still have the packaging but will see what they say. I should have ordered 1 of each dimmer prior to the start of this project and checked things out, hindsight is 20/20.
Installed Evolve LRM-AS as replacements for the GE I was having issues with. All my problems are gone, expensive mistake but I’ll not do that again. I’m able to dim a single Cree 6" Can Light Retrokit 9.5W down to about 5% with no flicker.
Amazon wouldn’t take the GE’s back, just attempting to sell them on Ebay for $10 off the normal price in an attempt to recoup some of the cost.
Thanks again everyone
