[quote=“juhiranjan, post:60, topic:172162”]I am planning to go for an antenna replacement on my vera3 unit.
Do I simply desolder the existing antenna and replace it with the new one, without making any circuit level changes?[/quote]
There’s nothing to desolder - take a look at the photo I posted earlier in this thread. You just unplug the U.FL connector and plug in the new connector that goes off the external antenna.
@big517
Make sure the antenna is designed for 900 MHz band … I did not look closely but your link indicated that this is for Wifi … that’s a different band. Antennas are designed for a particular frequency. Their performance decreases as you move away from this frequency. How fast is a function of the Q-Factor for an antenna.
A high Q filter drops quickly … i.e. is is very frequency selective and rejects other frequencies. Most antennas are a fairly low Q-Factor design … so they work on a wider frequency range.
@juhiranjan
No soldering needed … But you have to have good vision … the antenna connector on the Z-Wave board is very small … and at my age … without the right glasses … it was tricky getting it inserted.
Chose this because this seemed to be one of the better ants with +9db gain and optional magnetic base mount. I’m just hoping I have the correct gender and connection parts right also. :o
Thanks all![/quote]
My concern is with the antenna, which is billed for WiFi (2.4, 3.6, or 5Ghz). Z-Wave operates on ~900Mhz…
Thanks, I cancelled that order and stuck with what you ordered. I only wish there was a higher gain option… 3db doesnt seem like much, but I think the fact it’s external will make a world of difference altogether.
Antenna gain is relative to a specific reference antenna - generally an omni directional “isotropic” antenna. Typically, these small antennas inside units have negative gain - ie they are not as good as the reference antenna. So, if the antenna in Vera has -3dB, then you’ve actually got a gain of 6dB over the existing antenna.
3dB is a factor of 2 gain - 6dB is 4 times the gain… Additionally, with an external antenna you can get the advantage of moving the antenna to a suitable location which helps further. One thing though, the thin coax that is generally used in these antennas has quite a high loss, so more than a meter or two and you’ll have lost another 3dB…
And to add a few more comments … range is the square root of power.
So double the gain (3db) is about 40% range increase.
A 4X improvement gain( 6db) is a 100% range increase.
This is more likely to improve Vera to device communications more than the other way around.
A high gain antenna will receive a weaker signal … but will also pick up more noise … so you will not significantly impact the Signal to Noise ratio of receiving information from a device.
This is where you would like a HIGH Q antenna (Narrow Band) … noise energy is typically wide band (unless its really near band interference!)
Have you received the parts for your VeraLite yet? I am looking to use the same parts from Amazon but wanted to make sure they work before ordering.
(I can’t send PMs yet)
Thank you[/quote]
Just got them yesterday! I will be deploying the antenna this week and reporting back.[/quote]
I connected the antenna last night and kept the antenna next to Vera, in its original location. After a repair/heal last night, each of the fringe devices gained one star. I am also able to consistently poll the devices [with limited testing] that were previously intermittent. I thought I would see more stars though… I will relocate the antenna in the next few days and see how that works out.
Keep in mind that I am comparing the performance to my stock/internal antenna-modded Vera (pictured, a few posts above). If I compared the results between my stock Vera, it is a more significant difference.
Folks … I hope you are ordering the RIGHT antenna!
The link a few posts up is the WRONG antenna … it’s for the Wifi 2.4GHZ band.
You should get an antenna that is tuned for the Z-Wave 900 MHz band.
@snovvman
Is your new antenna designed for 900Mhz ?
Are guys finding this antenna is being drop shipped from China? I have another 2 weeks to wait. Same for the connector. Seller is uxcell. I’ve purchased from them before but i wouldn’t have this time if i knew i would waiting for 3 weeks.
I also ordered from uxcell using Amazon. Did this just Thursday so no idea on wait time.
I plan on installing one set here at home on a Veralite to test the effectiveness. Then on a Vera 3 at my rental house. I bought both a 7 dB gain magnetic mount and two 3 dB rubber antennas to see how they differ for overall gain. Rubber duck antennas from ReadyMadeRC as I wanted to ensure quality as that is my preferred solution. I surely hope it is as easy as has been stated here.
Thanks for sharing the pictures, your VeraLite looks great !
Looking back through the thread I couldno’t see what you had purchase, and seeing that you’re in the UK, I’m curious what you exactly bought and where you got the two parts from?
