Antenna on Vera3 -- extending?
From memory, the FCC compliance regulations don’t allow transmitters in this frequency band to be modified in any way, specifically in relation to antennas. All part of working in an unlicensed band. I might be wrong about this, but certainly worth reading the small print…
[edit] I have just checked an FCC statement on one manufacturer’s manual and it says:
FCC NOTICE (for USA):
THE MANUFACTURER IS NOT RESPONSIBLE FOR ANY
RADIO OR TV INTERFERENCE CAUSED BY UNAUTHORIZED
MODIFICATIONS TO THIS EQUIPMENT. SUCH
MODIFICATIONS COULD VOID THE USER’S AUTHORITY TO
OPERATE THE EQUIPMENT.
Well remembered akbooer!
I’ve also just ordered a cable and antenna. I intend to drill a hole in the back of the Vera to fit the antenna… It should be a 5 minute job and I’m hoping it will allow me to communicate with devices in my garage.
Chris
@Chris & JGreen1280
I never found the time to mod mine, so I eagerly await to hear how you both get on.
Seeing as ZWave is a mesh network and designed to build and extend itself as more nodes get added, i was not sure of the beneift of improving the antenea, but having Vera available directly to more nodes can’t be a bad thing. Can it ?
This is true if you can (easily) fill in the holes in the network by adding a node - eg add a power switch somewhere to bridge the gap. However, where this isn’t possible, improving the antenna should help both receive and transmit signals…
At least, that’s my hope :slight_smile:
Cheers
Chris
[quote=“parkerc, post:24, topic:172162”]@Chris & JGreen1280
Seeing as ZWave is a mesh network and designed to build and extend itself as more nodes get added, i was not sure of the beneift of improving the antenea, but having Vera available directly to more nodes can’t be a bad thing. Can it ?[/quote]
I will definately keep you posted… (Sorry for the late reply, apparently, after first notification of new comment on thread, I didn’t receive any more).
Please note that any hardware changes done to the Vera unit will VOID your warranty and it’s possible to lose communication with your Z-Wave devices.
It’s a known fact that the walls are diminishing the Z-Wave signal and metal objects might block it entirely, therefore it is not recommended to place z-wave devices (including Vera) inside metal cabinets or behind metal doors that may produce issues in your home automation network.
We recommend to put Vera in an open space and in a more central position.
[quote=“mcvadi, post:27, topic:172162”]Please note that any hardware changes done to the Vera unit will VOID your warranty and it’s possible to lose communication with your Z-Wave devices.
We recommend to put Vera in an open space and in a more central position.[/quote]
Thank you for this information.
What I have seen:
My house was built in December of 2006. It is a 2 story house with basement, 2,860 square feet.
My controller, Vera 3, is in my living room (on its side with top of Vera facing west) under my TV on a wooden shelf. About 16 feet, west of the Vera, I have a Kwickset Zwave lock and a Zwave door/window sensor on my front door. There are times when the Vera loses connectivity, briefly, with the door lock and door sensor.
Additional info: The front door is adjacent to the ‘formal dining’ area, which is adjacent to the living room. The wall between the formal dining area and the living room/family room had a window/shelf opening in the wall, which has been closed.
Prior to closing this wall, the top of the Vera was facing east and I was seeing intermittent communication issues. After the wall was closed, my success rate when polling or controlling the devices on the front door was about 5%, if that. As a test, which became a temporary solution, I flipped the Vera over (in the exact same spot) so the top was now facing west and angled it slightly so the top of the Vera was more south-west than west. This significantly enhanced my success rate. I now would say polls and controlling is now at about 95% successful. The 5% of the time the lock fails is because the front door is open, the controller loses communication with the lock.
Where I want the controller is underneath its exact location in the basement (basically down 5 more feet), near my network equipment (ASA, Switch, Cable Modem, UPS, etc.). I have no issues placing outside the rack, however, when I attempted to place it on the rack (about 1 foot from the basement ceiling), the lock would work from the basement, from the TV stand, from my sofa. As soon as I approached the wall in the picture (the area with the red box), Vera could no longer communicate. I couldn’t have been more than 10 feet from the controller, with simple housing sub floor between me and the Vera.
This is my dilemma. So, if what I read is correct, when I want to add out-door motion or temp sensors, basically I need to buy another Vera for each sensor I install, and place the Vera a few feet away from the sensor - but inside the house to protect from weather elements? Or, buy more switches, which come nowhere near where the exterior motion sensors will need to go? If I decided to zone my hvac system as a next step in my HA project, as it sits today, the controller would be unable to talk to my thermostats or occupancy sensors in the bedrooms on the 2nd floor.
I like the Vera, I really do, however I don’t live in a 10k square foot mansion. It is an average sized home in the US. It baffles my mind how weak the antenna is, or maybe just the RF amplification on Zwave - which I completely understand is regulated via FCC. I just want the range to be extended so the controller can talk to a device 30’ away. Heck, my Bluetooth on my smart phone works at greater distances in my house than the Vera from the devices it controls.
(Edited: Forgot to attach image)
JGreen1280…
I completely understand the frustration - I have difficult areas in my house too (actually 175 years old - the house, not me - with solid 18-inch thick stone walls and metal wall boxes for switches…)
What you haven’t indicated on your layout is whether you have other modules around which can act as relays. I put in a few superfluous switchable wall sockets to increase coverage and it’s worked well.
I’m not familiar with building practices in your part of the world, but I have noticed that newly-installed insulation in some new internal cavity walls that we have installed recently is actually metal clad to reflect heat… a really good RF screen. I wonder if this is the case for your filled-in window/shelf opening?
The problem may not be the rack itself. What you have around that area may be causing interference. I recently bought an IP camera and the cheap power supply completely nuked my ethernet-over-power connections. Replace with higher class power supply and all works well.
I don’t know whether any of this can help. I’m sure you’ve done your homework. The secret of a reliable HA system, it seems to me, definitely rests upon the robustness of the underlying communications architecture. Zwave really is quite good. There must be some additional factor.
I just added an external antenna to my Vera lite. Huge improvement. Even though my lock was about 30 feet away it lost the connection most of the time. Now it has Four star signal quality in the heal report. My thermostat, same thing. Went from 1 star to 4 stars.
Modification took a couple of minutes.
Thanks for the update!
I just received the last part yesterday (it was lost in the mail so the vendor shipped a new one).
I haven’t installed it yet, only because MicasaVerde says it will void warranty, so I am looking for a way to fabricate an antenna mount to avoid having to drill or screw any holes into my vera 3.
I received my antenna a few weeks a go; didn’t realize that the 5dbi antenna I purchased was so long (a little over 1 or 1.5 feet long). The 3dbi is likely much smaller.
I’ve now also completed my little modification :wink: and I’m quite happy with the result. All devices have gone to 5* signal on the heal report, where previously I had a number that were only 1 star.
Personally, I’m not too bothered about the warranty issue (but that’s just me). I’ve had my Vera over 12 months, so I’m not actually sure if the warranty still applies!
The modification is pretty simple. I’ve attached a picture of my finished product (with the top removed). You can clearly see the z-wave board and the new antenna. The internal antenna is glued to the top of the Vera case - I taped over the connector to electrically insulate it, and then taped it to the top of the case (being careful to avoid covering the ventilation holes!).
Cheers
Chris
[quote=“Chris, post:32, topic:172162”]I’ve now also completed my little modification :wink: and I’m quite happy with the result. All devices have gone to 5* signal on the heal report, where previously I had a number that were only 1 star.
Cheers
Chris[/quote]
good job
where have you purchase the antenne ? and connector
thanks
best regards
I bought them both off eBay - a 10cm SMA chasis to UFL cable, and an 868MHz antenna (ANT-900MR).
I’ve moved my Vera back down the other end of the house - previously it couldn’t reach all the devices from there, but now it can. I’m just running a heal to see what the signal is like, but it seems to be working nicely :slight_smile:
Chris
Chris[/quote]
thanks
i have found
http://cgi.ebay.fr/5pcs-IPEX-UFL-To-SMA-Male-Adapter-Cable-10cm-0016-/281012536442?pt=LH_DefaultDomain_0&hash=item416da7047a#ht_646wt_946
and
http://cgi.ebay.fr/EASY-RADIO-ANTENNA-WHIP-90DEG-868MHZ-ANT-900MR?item=121043612207&cmd=ViewItem&_trksid=p5197.m7&_trkparms=algo%3DLVI%26itu%3DUCI%26otn%3D2%26po%3DLVI%26ps%3D63%26clkid%3D5036194860928454618#ht_2459wt_1139
it 's good ?
Yes - the antenna looks like the same one I bought and the cables look fine as well. I found a supplier selling just a single cable here -:
http://www.ebay.co.uk/itm/370640100553?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Cheers
Chris
[quote=“Chris, post:36, topic:172162”]Yes - the antenna looks like the same one I bought and the cables look fine as well. I found a supplier selling just a single cable here -:
Cheers
Chris[/quote]
cool
thank you very much I’m ordering to change the scope of my too short vera lite
i
Hi @Chris and @rondave
How are thing going?
Have you noticed anything strange occur yet?
Can you now see Vera (node 1) listed in the neighbours list of certain devices where it was not listed before ?
Are there any improvements in the log file, do you see fewer NO ROUTE messages ?
I wonder what the range is now with this antenna, has it changed things to work more in a unicast mode rather than a multicast ? (I think that is the correct terminology)
@rondave do you have any photos to share of your modification ? If so, it would be appreciated.
Fine here -no problems at all. …
No - I wouldn’t expect anything though.
I’ve not looked at the neighbours list, but I can now communicate with devices that couldn’t even be seen before.
[quote=“parkerc, post:38, topic:172162”]Are there any improvements in the log file, do you see fewer NO ROUTE messages ?
I wonder what the range is now with this antenna, has it changed things to work more in a unicast mode rather than a multicast ?[/quote]
Not quite the right terminology I think - mulitcast means one to many where you really mean single versus multi hop routes. I do see some data being routed still (assuming my interpretation of vera data is correct!) But at least now I can see all my devices and most have 5* signal :slight_smile:
Cheers
Chris
Thanks @Chris
What you’ve done is really encouraging and shows promising feedback (so far)…
I do wonder why MCV did not go for the bigger antenna, I can only assume it was a cost decision? Yet on the Vera 3 it would surely have been less of a barrier, compared to the ‘budget’ Veralite
Looking at the Fibaro Home Center 2 - that uses a more obvious external antenna
