(Vera APP) Ezlo Plus
I’m making a scene for Christmas lights
List item
add scene
add activation event
Date and time
Daily
5:00 pm
Add Action
Device
(I choose several devices) hit Next
Turn on hit save
Thank I want to add action to wait x hrs than turn off but it will not allow me to set delay for multiple devices but if I pick 1 device it allows me to delay for x hrs and turn off.
Than I tried doing same in MeshBOT on MiOS
I create New automatic meshbot local
I add Trigger (date and time)
I try Custom time / special time of day Neither allows me to set a time. Custom time, I will assume, After / before / between is the correct time.
I add action and I have to pick all devices but cant do by room for all devices
than I cant add off time or wait X hrs to turn off the “group”
Not sure what Im doing wrong. A little guidance would be appreciated.
And that’s exactly why I told them we need to be able to add delays as a separate action item rather than being linked to some other action where you can append a delay.
Yet that advice has not been taken onboard currently.
Hello @peterg88,
I don’t think this is intended behavior. As you said, it can be done if you configure each device separately but I think the app should let you add a delay not only when you select only one device under “Actions” but also when you select two or more. I have escalated this case to the Android department. They should be working on it soon.
Thanks for the heads up. Kind regards!
It is possible to cover your case for devices on specific controller. The simplest way you can create a MeshBot as on the picture. (I use dimmer and switch)
Ok I logged back in and that resolved the issue with adding action. Here is what I added as you see I set delay for 5 minutes to turn off (that was about 20 minutes ago.
Could you please clarify, you want to turn off Z-1 device after 5 min of Action started to work or 5 min after XM-2 device turned off.
For now, these actions are independent and your Z-1 device will turn off after 5 min of Action started to work.
If you want to turn off Z-1 device after XM-2, I suggest you to change delay to 7h and 5 min.
