Here is the guide I created on how to add a Amcrest ProHD 1080p 30FPS WiFi IP Security Camera IP2M-841 to the Vera after contacting Vera support. Hopefully this helps others.
Thanks for the information it helped me!
Worked perfect for my Amcrest IPM-723 Bullet Camera
Looks like a much easier way to install.
but i get:
“Error: invalid service/action/device”
When i try to use on my Amcrest IP3M-941B
I’ll keep trying…
[quote=“l8nighter, post:1, topic:196286”]Here is the guide I created on how to add a Amcrest ProHD 1080p 30FPS WiFi IP Security Camera IP2M-841 to the Vera after contacting Vera support. Hopefully this helps others.[/quote] A utube video would be great…I have been using vera lite and now plus for a couple of years.I am not good at the tech stuff…But thanks
Thanks a bunch l8nighter, made the install of my new Amcrest IP3M-956 a breeze after wasting some time trying to configure the API URLs in the new camera wizard
Do you by any chance still have this guide handy please?
Amcrest ProHD 1080p 30FPS WiFi IP Security Camera IP2M-841.pdf (100.6 KB)
See attached document from the old forum.
Just installed a Amcrest IP4M-1041B IP camera on Vera with firmware version 1.7.5185 (7.31) using the step outlined in the Amcrest ProHD 1080p 30FPS WiFi IP Security Camera IP2M-841.pdf.
Thank you for sharing your skills and time with us.
No worries glad it helped.
