Almost embarrassed to ask, but what is a nice clean way to always ARM a sensor when Vera is started, i.e. after power down etc. It’s a water leak detector, and no reason to ever “BYPASS” it.
The “LaundryRoomWaterDetected” scene just sends a message via PROWL to my iPhone with some LUUP code, but will only run if the sensor is ARMed, even though the trigger is set to - “A Sensor is tripped”?
