[quote=“amg0, post:16, topic:188333”][quote=“BatterBits, post:15, topic:188333”]I really like the themes, and especially the dark themes. On most of them however, there is an issue with reading text somewhere!
On all the dark themes for example, if I view Devices/AltUI/Settings, the three configuration buttons are all unreadable - light text on a light background. Similarly, with the text under the switch (grey on blue) on the control tab
And my favourite “light” theme, Flatly, in the “Event watcher” device, the control section has green text on light blue, which is very difficult to read.
Are these things that are easy to fix? I can’t see that anyone else has mentioned it, but I’m sure it must affect everyone.
I am using AltUI v0.95.859, and Firefox[/quote]
I ll a have a look to see if I can make these a little bit more following bootstrap cuss standards, but in any case you can fix it by downloading the bootswatch theme and customize it or add your own additional rules , make your own css file and declare it in the themecss configuration variable of altUI device[/quote]
confirmed, I changed ALTUI settings page to use bootstrap style in buttons so that it is aligned to the theme choice whether the settings page is viewed inside UI5/7 or ALTUI, but other plugins could have the same issue and the only way is to create your custom css.
for instance, I use the Slate one, but I customized it so that the switching point is smaller such that landscape rotation on iPhone6+ gives you a desktop view, plus added some darker barkgrounds to bg-info as the one from bootswatch theme a light blue.
My custom css is like
... here goes all the bootswatch Slate one with modified switching point for 'small'screen...
... then the following lines after ...
td,button,select {
color:rgb(142, 142, 142)
.bootgrid-table th>.column-header-anchor {
color: white;
.bootgrid-table th:hover,
.bootgrid-table th:active {
background: rgb(187, 187, 187);
.bg-info {
background: #03084C;
then that file can be put somewhere on your vera, or what I personally do,is I put it on my googledrive and declare the url to download it in the THemecss variable of ALTUI. in essence Google drive becomes my web server !
