Curious to see some screenshot of people that have a custom theme for ALTUI…
Not a huge fan of the “builtin” theme…
There is, of course, a range of options under Misc > Themes …
…not enough ???
[quote=“akbooer, post:2, topic:194318”]There is, of course, a range of options under Misc > Themes …
…not enough ???[/quote]
I know but not enough, they are all the same except some colors changes ![]()
…but all SO much better than UI7 !
…but all SO much better than UI7 ![/quote]
You’re right, but it will be way better to have something more like https://wrapbootstrap.com/theme/smartadmin-responsive-webapp-WB0573SK0
Have you looked at Grafana?
You’re right, but it will be way better to have something more like https://wrapbootstrap.com/theme/smartadmin-responsive-webapp-WB0573SK0[/quote]
it is open for people to do their own … and even better then , share with others in the Theme/css thread!
the constraint to respect => must be based on bootstrap 3.3.7 and must evolve when I evolve the boostrap version of ALTUI. i am not expecting so many updates but a big one will be coming with bootstrap 4.0 (I ll probably switch to ALTUI v2.0 at that time …)
I really need to install Grafana later next weekend to have some graph… but the main interface, I need to find some time to play with a theme like the one I posted…
the constraint to respect => must be based on bootstrap 3.3.7 and must evolve when I evolve the boostrap version of ALTUI. i am not expecting so many updates but a big one will be coming with bootstrap 4.0 (I ll probably switch to ALTUI v2.0 at that time …)[/quote]
amg0,
Are you using a custom theme or the “builtin”? ![]()
I use bootswatch slate min.css file for my main system , and nothing on my secondary system
amg0,
Are you using a custom theme or the “builtin”? ;)[/quote]
@akbooer, are you having some documentation/note that you take when you install/configure/use it? ![]()
@akbooer, are you having some documentation/note that you take when you install/configure/use it? ;)[/quote]
…what did you have in mind? All I know is somewhere here: http://forum.micasaverde.com/index.php/topic,39612.0.html
I just followed the instructions for an install on RPi and it worked. Only thing to know from the openLuup end is that you need the latest development version on DataYours and you need to manually install the graphite_cgi.lua file. (OK, that’s not quite true, but if you want to follow up further, let’s use that thread.)
