I am trying to access the ALTUI pages that is on a Pi with the latest openLuup and everything using my Andoid 5.x or 6.x phones. However, it never gets passed the Waiting initial data message. I have tried with Chrome, Firefox and Opera, but all produce the exact same result. As it is on a phone I have no idea on how to possibly debug.
Bit annoing I have to start my PC to look at the openLuup installation. Any suggestions?
Cheers Rene[/quote]
Does it work on vera UI?
Which version?
Check where it hangs using browser network tab for uncomplete downloads and js console for script errors
WE had issues in the past with large downloads
Works fine with ALTUI running on a Vera, just not for the instance on my Pi.
I tried two phones. One is a Nexus 5 with Android 6.0.1 the other a Sony with 5.x both up to date.
I am not seeing a network tab in any of the android browsers nor an option for a js console. The only thing I can find is remote debugging via USB. I’ll see if I can give that a try.
Cheers Rene[/quote]
hum… typical painful to debug. are you sure your openluup setup is full up to date, with web server support http 1.1 and chunked transfer ? also socket size and timer may need some tweaks, some files are big to download…
Indeed a pain to get the remote debugging to work. But in the end I managed. Is also found the issue. It the language. My Phone is set for Dutch (NL), so that is the locale ALTUI tries to open and it fails to. Adding the lang=en option has solved this now. Lots of trouble for finding an option ::).
Anyhow, it now works. And if you get more issues like this, it is one to watch out for.
Cheers Rene[/quote]
Thanks a lot for this effort. I normally defaults to en but I need to check what happens here.
have a nice new year’s eve
Cheers Rene[/quote]
one way is to create another file called J_ALTUI_loc_nl.js as a copy of J_ALTUI_loc_fr.js for instance and translate the strings in it into Dutch language. then deploy that file at the same place as other ALTUI file. you can give back that file to me and I ll include it in the distribution , that will make ALTUI support another language…
Cheers Rene[/quote]
one way is to create another file called J_ALTUI_loc_nl.js as a copy of J_ALTUI_loc_fr.js for instance and translate the strings in it into Dutch language. then deploy that file at the same place as other ALTUI file. you can give back that file to me and I ll include it in the distribution , that will make ALTUI support another language…[/quote]
Hi, I can sure have a look at that. Howver, where can I find the Original English texts to start? I am clueless on French and Spanish :o
Cheers Rene[/quote]
Cheers Rene[/quote]
The file have a data structure key : value , and the key is always in English text, so you leave the key untouched and change only the second string (the localized. Value )
If you use text speech recognition, you can also localize this but in that case I will give you more assistance, information.
Attached is a Dutch locale. I doubt it is perfect as I am in no means a translator, and Dutch is a not a techology friendly language.
In the process I did notice that the Watch Display and Power chart are not working. The first on a Vera and openLuup. The latter only not on openLuup.
Also blocky starts to play up. I guess that wants a locale as well. If you tell me how to get that I can test it a bit more.
Cheers Rene[/quote]
ok thx. I think powerchart depends on a legacy url that openLuup does not support maybe. check with akbooer
http:///port_3480/data_request?id=live_energy_usage
regarding Watch Display can you be more specific, maybe with a screen shot of what page is not working and maybe check out the chrome javascript console for any sign of error; could be a corruped watch desciption crashing the javascript
On the WatchDisplay I get no error, nothing. looking at the Watch Tabel I do see an empty watch. It has only a number but none of the other parameters is populated. When I try to delete it is trows this error.
GET http://192.168.178.21:3480/data_request?id=lr_ALTUI_Handler&command=delWatc?e=&scene=&expression=&xml=&provider=&providerparams=%5B%5D&_=1484078850035
500 (Internal Server Error)
Editing is not an possibility either. That gives this error.
Uncaught TypeError: Cannot read property 'altuiid' of null
J_ALTUI_uimgr.js:12601
When editing one of the scenes I now get this
error happened during decoding triggers, probable duplicate ID or invalid format
Any suggestions on how I can get rid of it?
i am seeing this in the states portion of the the user_data.json that looks suspicious if you ask me
Anny suggestions on how I can get rid of it?
Cheers Rene[/quote]
give me your variable values : VariablesToSend and VariableToWatch.
you can also check lua logs when running in debug mode
I changed VariablesToWatch to this and that makes the Watch table show as expected again, that empty entry is gone. Looking in the log file the actual watches setup at s LUUP start was going correctly. It ignored that empty/corrupt entry.
The second list on the TblWatches page still has one empty entry.
The graphic Watch Display page remains blank with no error messages shown what so ever.
I did manage to isolate the issue with the error message on editing the one scene. I tried to set notification triggers on openLuup and I pointed that to a device on an other Vera. Then I removed that device from the Vera before removing the trigger, hence the device ID in the trigger became invalid. So changed the device number in the user_data.json and that bit is now fixed. Maybe the code should be changed so that triggers on removed devices, even the ones created via VeraBridge get dumped from the configuration automatically.
