I’m attempting to download some apps from AltUI, when I select download, I get a red “failure” button. Any ideas as to how to fix this? Thank you.
I had the same problem. See this post http://forum.micasaverde.com/index.php?topic=38297.msg292704.msg#292704
…you do actually have the AltAppStore plugin installed already?
Make sure you click the Vera button when trying to install on a Vera and AltUI button when doing it on openLuup.
Cheers Rene
No, that’s not quite correct. The Vera button will use Vera’s built in updater for apps that are in their App Store. The AltUI button will download from the AltAppStore using the plugin.
No, that’s not quite correct. The Vera button will use Vera’s built in updater for apps that are in their App Store. The AltUI button will download from the AltAppStore using the plugin.[/quote]
For me the update on openLuup only seems to work with the ALTUI button, and the Vera button on a Vera. Not sure if that is a bug then. Using Firefox on Win 10 and PI for openLuup.
Here’s the error I’m getting:
09/08/16 8:51:47.020 eluvd_get_info mg conn can't read /etc/cmh-ludl/D_ProgramLogicC.xml or /etc/cmh-lu/D_ProgramLogicC.xml from filename /luvd/D_ProgramLogicC.xml pPtrFile D_ProgramLogicC.xmle <0x72f33520>
Yes, I am using the altui download link and not the vera one. Attached a screenshot.
If this is a permissions error, do I fix this via SSH or the AltUi OS Command?
The ProgramLogic error looks more like PLEG than anything else?
I think I sorted it out. I manually installed the github files for the altappstore and all seems to be working. Thanks everyone.
