[quote=“cybrmage, post:80, topic:199107”]Also note:
In ALTUI (under both UI7 and openLuup), the warm white/cool white selections sliders (for color temperature selection) are not displayed in the control panel… This appears to be an issue with processing the D_DimmableRGBLight1.json file.
Under openLuup, the color selection dropdown on the device page does not display the correct color, the color selection dropdown in the device control panel does display the correct color.[/quote]
What?s the value of currentcolor variable in both case
The display of the file is a bigger pb. Ui7 does not follow the file and hard code a display ( like it does for?most Built in devices). I think a custom panel for altui would be a better option and not care about ui7. This is a simple JS method declared as a Altui plugin in case somebody is interested to contribute to it. Also the upnp setcolor with the syntax Wxxx or Dxxx should work to set the color temp of the light
