Alternating devices
Would like to force my AC units to alternate on/off when house is on generator power (i.e only one of the two on at a time)
Each one should go on for 30 min at a time.
How would I write I reactor to do this?
The root is true when generator is on and cooling day is on.
Do i use an interval of 30 min with a delayed reset of 30 min and use the true/false of that condition?
any ideas?
I think i got it…
Interval of 60 minutes with a delayed reset of 30 min. goes true for 30 min - stays false for next 30. wash rinse repeat as long as root is true
You might also look at the Pulse output mode for conditions and groups.
https://www.toggledbits.com/static/reactor/docs/3.6/Condition-Options/#output-control-options
i did - but wouldn’t pulsing the root cause the reactor to untrip for that time?
Whether or not that matters depends on how you build your logic. The “modern” way of building it in Reactor makes the tripped/untripped state of the ReactorSensor irrelevant.
Ok. Thanks
