An alternative UI for VERA boxes based on UI5 UI7
msg1 of this thread has been replaced by
[url=http://forum.micasaverde.com/index.php/topic,33302.0.html]http://forum.micasaverde.com/index.php/topic,33302.0.html[/url]
That looks nice, an UI where you can se more than 4 device at the same time on the screen that is amazing ![]()
I will download and test as soon as I’m of work.
I doesn’t work
I have uploaded all the files from http://code.mios.com/svn_public/mios_ipx800/trunk/AltUI/ to my Vera Edge (except the pdf ofcourse) and restarted lua but when I access http://192.168.0.10:3480/data_request?id=lr_ALTUI_Handler&command=home#
I only get “No handler”
[quote=“olaeke, post:3, topic:185570”]I doesn’t work
I only get “No handler”[/quote]
I am pretty sure it does, are you sure you waited your lua to restart ? ( takes some time ). the plug in is ultra simple. you are on UI7 right ?
just added windowcover support.
Looks great. Will this work on UI5 or does it require UI7?
UI5 not tested. but I am pretty sure UI5 changes should be minimal as subsystem dependency is minimal. I only depend on a plugin ( to do a handler ) and the icon files. I reuse the icons/images and the dynamic icon logic described in devices json files , I have implemented both the ui5 and ui7 logic
I’ve not tested… But wow…good work!
thx ! just added device rename feature. ( click on device title, rename and click away ). almost instantaneous …
UI5 on a Veralite G, I went to Apps/Develop/Luup files and uploaded all the files except the pdf (13 of them) and selected restart Luup when finished
Then I went to the address http://veraip:3480/data_request?id=lr_ALTUI_Handler&command=home#
I get a No handler message (tried in Google Chrome desktop)
I tried a reboot as well, same result
Screenshots look great though, I look forward to getting this to work
i cant get the pdf to open
I too cant open the pdf ![]()
Trying again with 2 posts:
Thanks,
It works on Ui5 now ![]()
Just added device variable view. ( variables are ordered alphabetaically & timestamp preseted as date … ) sounds trivial but allways been a grief I had against UI5 & UI7 that variable are not ordered and timestamp are unix timestamp. not really user friendly.
cant wait to try…
I have added some new key features:
screen shots & install instruction is in the PDF doc.
[url=http://code.mios.com/trac/mios_ipx800/export/171/trunk/AltUI/doc.pdf]http://code.mios.com/trac/mios_ipx800/export/171/trunk/AltUI/doc.pdf[/url]
code is in the same place [url=http://code.mios.com/trac/mios_ipx800/browser/trunk/AltUI]http://code.mios.com/trac/mios_ipx800/browser/trunk/AltUI[/url]
enjoy
hi amg0, thanks again for this. I got the first version up and running on UI7 and its definitely got promise!
One request please. Could you zip up the files on code.mios.com into a single zip to d/l ? saves time downloading from the site and uploading for each version.
Thanks again
For the files, you can use this “link” : [url=http://code.mios.com/trac/mios_ipx800/changeset/176/trunk?old_path=%2F&format=zip]Diff from /@182 to trunk@182 – IPX800
but then please only install the files in the AltUI folder of the archive.
