I just started to use the Alternate UI and the first thing I noticed is that it uses my added “other” user when it tells me that it is unregistered.
When I check the Vera user list, only the secondary user account is in the list but the main user is available for scene notifications.
Is this a bug or did I miss how to change the main user in Alternate UI?
Altui just need a unique user name and it gets it from the list of users declared on your VERA. it actually takes the very first one on the table so it is a little bit undeterministic which one it ll use, that is why it displays it in the footer.
if you register, you tell me what it is and I register that name. but it should be really be the user you use to connect on MCV servers & store because that way it is unique
