This is their “newer” MIOS app based on the Vera app, it has more features however like being able to access the dynamic dashboard that you also see in the web UI. Maybe check that app out.
But again I would only recommend creating and editing scenes / rules in the Ezlogic web UI for now !
thanks for the feedback. We will prioritize this problem and publish an update asap.
Also @cw-kid pointed out our MiOS app which is meant to control Ezlo controllers. we haven’t launched it officially but it has the exact same capabilities a vera mobile app has.
we will launch it shortly as well.
@osman Thanks, couple of things I could not find on the iOS MiOS app is how to configure and switch between Home, Away, Vacation modes… Pretty important since it was the ONLY way I was able to stop the Linear Garage Opener siren going off. Thanks!!!
Hi @augustov can you tell the exact scenario pls, so maybe we can guide you to achieve the same result with meshbots.
We are fond of meshbots and thinking to achieve all the same functionality you can with house modes with meshbots, for now there is no house mode changer on MiOS app.
Hi @osman I added a Linear Garage Door Opener to my Ezlo and it created 3 devices, the Garage Door Opener itself, the Garage Door Siren, and the Garage Door Indicator (in my old Vera unit it only created the Garage Door Opener not the other 2) The problem is that I could not find ANYWARE to disarm the Siren, and EVERYTIME I went to my garage the Siren went off. The only place where I finally was able to disarm it was in the Home mode section of the iOS Vera app. Hope that helps…
I had the same problem with finding the Home, Away, Night, and Vacation modes as well. I’ve attached screenshots of the steps to access setting the different modes.
Click on the icon that the red arrow is pointing to to access the next screen in sequence.
The screenshots are from the MiOS app for (iPhone), App Version 1.4 (3)
Thanks Osman, I was aware of that, but others may not have been.
The biggest issue I have with House Modes on the Ezlo platform is that a massive part of it is just missing when compared to the Vera firmware hubs.
On the Ezlo platform we have no “What to do when this mode is selected?” section.
This section lists all your devices on a single page and you can easily select what happens to those devices when the different House Modes are initiated. e.g. ON or OFF or No Change etc.
I know you are saying we can do the same thing in Meshbot rules and that is true, however its a major ball ache to create a Meshbot rule with all your devices in it, as its very time consuming and also I would need four similar rules with all my devices in the Actions for the four different House Modes etc.
@cw-kid
I can’t really help with an Android MiOS app, as all I have and use is with an iPhone. You’ll need to check with someone who is working with, or programming, the Android version.
Hope you get it identified on how to access that portion.
Most of the House Mode stuff seems to be present already in the Mios iOS app. Just that “What to do when this mode is selected?” section appears to be missing currently.
