I’ve upgraded my AU Vera2 with a dongle to a Vera3 using the following procedure:
Upgraded to the latest UI5 on my Vera2
Backed up my configuration to a file
Installed my Vera3
Upgraded it to the latest UI5
Restored my previously saved configuration file
At this stage I noticed all my devices were listed, however I couldn’t communicate with them and had “No zwave dongle” displayed. I then changed the port setting to /dev/tty/s0 and all my devices were lost! All my scenes etc exist, but of course don’t work because there are no devices.
Opa, it sounds like your Z-Wave network is still “on” the stick you were using for Vera2, and that you haven’t yet transferred it to an inside-Vera chip. Try this first and see if it works.
Plug the stick into the Vera3. Set the Z-Wave port to: /dev/ttyUSB0 (one digit, three capitals). Then reboot.
This is basically how I work (because my internal Z-Wave radio is a US one and hence useless).
If this works, you’ve ruled out any hardware issues with the Vera3.
Using Setup > Z-Wave Settings > Advanced, back up the USB stick’s Z-Wave network.
Change the Z-Wave port back to the internal Z-Wave chip (/dev/ttyS0 or whatever it was when Vera shipped to you).
Pull out the USB dongle and reboot.
Restore the backup you made in step 1.
No idea if this works, though. I’ve never had to do it. Maybe it’s time to put in a support email (since you’re no longer in a desperate hurry). Point them at this thread on the forum.
Futzle, I tried that, but no joy unfortunately. I’ve got a support email in and they’ve pretty much suggested the same as you, so I’ve let them know it didn’t work. We’ll see what they come up with next. I’ll keep you posted.
I am curuious why you said “or whatever it was when Vera shipped to you”. Could it be that I need to set it to something other than /dev/ttyS0 for use in AU? Of course I no longer have what it shipped to me with…
AFAIK, MCV Tech Support has a way of restoring just the Z-Wave database. Presumably to any target (USB dongle, internal chip, etc.). I was also told a while back that the Z-Wave database backup is indeed compatible between targets.
An update…support have managed to get all my devices back, and I am now operating without the dongle. However, all my devices have lost their names, and none of my scenes/triggers work. Support are still working on it…
A final update…support were unable to retrieve all my device names, so I had to reset them all manually, and redo all my scenes/triggers manually. Fortunately my network only has some 20 devices (so far)! Other than that, my Vera3 seems to be working fine.
Hi OPA…Can you please tell me what changes you had to make with the help of the support team… I am having similar issues… I have upgraded from vera 2 with dongle to vera 3 and lost all my settings…I have backed up my previous setting from vera 2, but its all stored in the usb. Cant get it to transfer to Vera 3 without dongle.
Thanks in advance
Cheers
DEV
