I also went back to using ha-bridge on a pi 3B and my brain still waits for the “hub is unresponsive” response but instead there is an instant action response. Glad to see its still being supported! @cw-kid Thank You for the Dim Items code. I’m not sure why that just wouldn’t be included by default.
I still have my thermostats in the cloud and based on @therealdb response I’ll test bringing them in locally also.
Thanks again for all the efforts around the ha-bridge and VERA support.
Hello everyone, I hope to get help from you, I have bought a raspberry to migrate my devices to node-red and get a solution to Alexa’s response. the node-red code works perfect and fast.
run these commands so node-red always starts after a power outage
node-red-start (for node -red to start as a service)
sudo systemctl enable nodered.service (so that node-red always starts from a reboot.
but node-red starts and alexa voice commands stop working unless i run this command and restart node-red
node-red-restart
and everything works again.
Apparently node-red crashes and does not start correctly after a reboot because it does not detect vera, since the wifi takes time to connect and I suppose it starts node-red first. I attach logs after restarting raspberry.
I dont use HA-Bridge anymore for Alexa. In fact I don’t even use Alexa, I have Google Home speakers in each room.
What happens if you ask Alexa “what is the thermostats current temperature” or “is door X open”.
It never even worked with the official Vera skill for Alexa or the Google Home service.
I can ask Google Home for the thermostat temperature, but ask it if a door or window or roller shutter is open she is clueless and responds “Sorry it looks like that device hasn’t been setup yet”.
However I can ask Google Home for the status of lights and appliance plugs, that seems to work and she tells me if its on or off.
Ezlo need to update them for Vera hubs, which is unlikely.
And their own new Ezlo integration for voice assistants I havent started testing properly yet.
And the local HA-Bridge I am going to say no it’s not possible, but don’t quote me on that, because I am not sure.
I’d have to search and read about it again.
Search this forum and have a look at the Github issues / discussions.
Is this it? I’ve no idea how up to date and accurate these are.
Q: Can voice commands other than: ON, OFF and DIM/BRIGHT be used?
A: NO, the ha-bridge emulates a Philips HUE bridge. The interactions between a Philips HUE and and Amazon Echo are determined by Philips and Amazon. They are not changeable by the ha-bridge, so only: ON, OFF and DIM/BRIGHT verbal commands are available.
Q: Can I get Alexa to respond with information, like temperature or device state?
A: NO, the ha-bridge emulates a Philips HUE bridge. The default response by Alexa for Philips HUE is ‘OK’ and is not changeable by the ha-bridge.
How did you initially install and setup node-red on the Pi ?
I followed these instructions here for installing node red on my Pi.
I am not using the Alexa node however. I am using the MIOS node though.
Can you post the contents of the nodered.service file located in /lib/systemd/system/
Mine looks like this:
# systemd service file to start Node-RED
[Unit]
Description=Node-RED graphical event wiring tool
Wants=network.target
Documentation=http://nodered.org/docs/hardware/raspberrypi.html
[Service]
Type=simple
# Run as normal pi user - change to the user name you wish to run Node-RED as
User=pi
Group=pi
WorkingDirectory=/home/pi
Nice=5
Environment="NODE_OPTIONS=--max_old_space_size=512"
# uncomment and edit next line if you need an http proxy
#Environment="HTTP_PROXY=my.httpproxy.server.address"
# uncomment the next line for a more verbose log output
#Environment="NODE_RED_OPTIONS=-v"
#ExecStart=/usr/bin/env node $NODE_OPTIONS red.js $NODE_RED_OPTIONS
ExecStart=/usr/bin/env node-red-pi $NODE_OPTIONS $NODE_RED_OPTIONS
# Use SIGINT to stop
KillSignal=SIGINT
# Auto restart on crash
Restart=on-failure
# Tag things in the log
SyslogIdentifier=Node-RED
#StandardOutput=syslog
[Install]
WantedBy=multi-user.target
Looks like your having a problem starting the mios-server ? Not the node-red-contrib-amazon-echo
