Alexa discover Ezlo connected devices
I’ve added a new plug, Zooz ZEN25 to my Ezlo Secure as a generic z-wave device.
I asked Alexa to discover devices but it doesn’t see it.
How can I get Alexa to see the plug?
Hello @chuckf2
Thank you for contacting us,
If you prefer we can start a support ticket with our Customer Care team for more personalized attention.
We will stay attentive to your response.
Can you not do it via the Alexa app and rediscover devices?
If its like the Google Home integration it may well be currently broken. I cannot add new devices in to Google Home at the moment.
Or on your PC try going to your Alexa account in the browser and rediscover devices.
https://alexa.amazon.co.uk/
or
https://alexa.amazon.com/
I assume you have been to home.getvera.com and selected the little drop down arrow in the top right of that page and then selected Manage Alexa Ezlo and then you have ensured the new device is ticked and selected and you have pressed save / finish on that page first ?
Going to home.getvera.com did the trick. All devices were checked but alexa didn’t get the memo until I pressed the Finish button at the bottom of the list.
Thanks again cw-kid.
Good glad you got it working and for confirming the Ezlo hub still seems to be working with Alexa.
Google Home not so much, when we recently were unable to add new devices.
I just added a new z wave outlet. It is paired with my ezlo secure and works fine.
I went to home.getvera.com to give alexa access but the device is not in the list. What can I do?
Hello @chuckf2,
Could you please try saying “Alexa, rediscover devices”?
We’ll be standing by for your results and feedback.
I’d already done that 3 times. I did it again but device was not discovered by alexa.
The outlet is a Minoston MP21Z. I paired it using the Z-Wave Smart Start which worked very well.
I named the device bedroom lamp. It replaces a Centralite 4200C zigbee device that used to work but now doesn’t pair. It was called bedroom lamp also. I telling you this in case there is an issue with replacing devices with the same name.
You can close this issue. The device showed up in the alexa list today. Wonder why it took so long.
