Again loop in luup
Since today after installing the hue update I keep getting:
googled on it and came to my own post years ago:
http://forum.micasaverde.com/index.php?topic=34878.0
Is that recover link still active? Or different now?
This is what fails to install/load…
There are no relation between hue and that message. That message is due to a small update of altui to fix some harmony plugin code. Just click yes and let it do its job for a few minutes
Thus if I click yes it shows the 2 blue lines forever… untill I click update in the app section of vera for altui…
The “hue update” was a typo in my first post. I meant “harmony update”
it can be long. wait long enough, also look at your logs, there could be a message here.
you can also try to reinstall altui from the vera App Store , it seems that it is extremely slow right now. even just to open the home url http://apps.mios.com so there could be an issue with App Store
in that case a workaround is to install the version on GitHub by uploading the files directly
It looks like the Mios App market is sloooow again. For a large plugin that may cause issues as it won’t complete the downloads in ten minutes and that is when the retry kicks in.
Also my latest updates to the app market have not been published yesterday as they normally are.
@Sorin, please have your team look at this.
Cheers Rene
Thanks Rene,
Will forward this and keep you posted
LE: Sysadmins say that apps portal should be faster now(please confirm). The app approval still waiting on confirmation.
Hi @slelieveld,
Have tried to uncheck the auto update for the ALTUI plugin on your Vera? You can then update the plugin in ALTUI directly. As that pulls from github the update will be fast.
Cheers Rene
