So I followed the standard controller migration procedure which includes a backup and restore of the settings. After I did that, however, the Zigbee settings are all gone! In fact when trying to add a device I get Z-Wave and Insteon options, but no Zigbee.
Please help!
Otherwise the controller works great and all the devices (z-wave) migrated over just fine. I don’t have any zigbee devices yet but will soon.
Firmware on the device:
Checking if there is a newer firmware version available…
You are running the latest version: 1.7.1754
One quick note – I went into “add a device” and then clicked “Other Devices” and the ability to add a generic Zigbee device is present and available. I wonder if the settings tab for zigbee will show up after you configure the first zigbee device?
I have managed to add a ZigBee magnetic door open/close sensor to my VeraPlus, so the ZigBee interface is enabled, as is Bluetooth :). The sensor has added OK and seems to work but it did fail in configuration creating a bogus _Scene Controller and the inbuilt temperature sensor was not picked up either.
I believe my settings tab for ZigBee was present before I added the device . It is of course present now, as are Bluetooth, Z-Wave and Insteon tabs - and I haven’t yet added any of those device types, the sole ZigBee device was just a first test. I realise this isn’t quite the same as I haven’t migrated, you lost Bluetooth settings too.
Update here – so the settings magically appeared after I simply hit refresh on the browser.
It seems that if people have issues with the UI - maybe it’s worth a “close the window/tab” completely, maybe clear some cache?, then load and force-reload the page to ensure it’s completely up to date.
