After downgrading VERA 3 U16 to U15 vera3 no longer operational :(
I was trying to get the USB UIRT working & read somewhere there may be a problem with U16.
I decided stupidly to down grade to U15.
After the downgrade I can sort of log in but when I click on GO TO LOCAL UI I get a 404 not found.
When I just type in the local ip address its just a lot of text down the side of the page but is not useable.
The devices still work when controlled by the smart phone but I cant do anything because the GUI is no longer useable. I read that I could do a factory restore but I don’t have the restore/reset button on the back of the unit.
I did do a backup but have no idea how to restore it.
Can I get the VERA# back to the way it was? & wait for a fix for the USB UIRT
Des
I am guessing that you have a brand new unit?
This happened to me too, and I intentionally reverted back to UI5 from UI6 after reading here about the inherent problems with UI6. I kind of muddled thru it, so my instructions may not be the greatest.
I found the issue I ran into was the password. UI6 requires a special character (!@#$) etc., whereas UI5 does not allow them.
can you access thru cp.mios?
If you have never accessed thru cp.mios, then register there with a non-special-character password and then try and access your machine.
Are you accessing your unit directly thru your browser and IP address? This is how I always access mine locally, and it works well. I did notice that I had to basically restart my computer after I downgraded for the UI to show up correctly. I have no idea why, but I did.
Thanks Vodden,
I have fixed the problem what i did was befofe you click the Go to local UI there is a option to click here if your unit is unassigned.
I did that & it came up saying that there was new firmware available & started downloading automatically.
When it all came back up I restored the latest backup & everything seems to be how it was.
Thanks for the advice
Now back to USB UIRT problem
Cheers
Beags
Any word from Vera support yet?
Hey Vodden,
yes support is currently working on getting the USB UIRT working
After that it will be back to the usb to serial adaptor issue
Cheers
Beags
Can anyone tell me where I find instructions to downgrade form UI6 to UI5 on my new Vera3?
See http://forum.micasaverde.com/index.php?topic=23161.0
Thank you.
