after 1.5.622 upgrade lost lock pins?
After I upgraded by vera3 to 1.5.622, all of the previously stored schlage door lock pins are no longer listed. I tried restoring the last backup saved 1 day prior to upgrade but to no avail. When I try to enter a pin code again vera says that the code is already in use.
Any ideas on how to fix this or to delete all stored but invisible codes?
Can you submit a trouble ticket, from Account -->Tech support → Continue and describe your issue?
[quote=“aecchalet, post:1, topic:174929”]After I upgraded by vera3 to 1.5.622, all of the previously stored schlage door lock pins are no longer listed. I tried restoring the last backup saved 1 day prior to upgrade but to no avail. When I try to enter a pin code again vera says that the code is already in use.
Thanks[/quote]
I ran across the same issue. Here is the workaround I used:
http://forum.micasaverde.com/index.php/topic,13956.msg105934.html#msg105934
I had the same issue after upgrading to 622. In my case the KeepPinCodes was already checked and the variable already existed. I unchecked and rechecked the button and did a save with no change. I then forced a “Configure Node right Now” and my codes showed up after configuration took place.
Thanks[/quote]
I had the exact same issue, put in a code, add restrictions and wait. Come back and the code is still there for a while but seems to disappear the next time the system polls the lock.
