The Aeotec Z-Wave Micro Smart Energy Dimmer is for dimming bulbs. It can have its dim level set by a Z-Wave controller or by a locally attached momentary switch. It can also be turned On/Off by a locally attached On/Off switch, but you cannot locally control the dim level with this switch. You cannot use a locally attached dimmer(rheostat, potentiometer, TRIAC slider) switch with the Aeotec micro dimmer.
It cannot be “paired” with a dimmer control only an On/Off switch or a momentary switch. The choice to use the Aeotec dimmer versus the Smart Switch depends on whether or not you are using a dimmable load(bulbs).
OK… let me kind of clarify, because I realize that my original post was a bit muddled, and I wanted to make sure I understand what you are saying.
So, right now, I have my lights controlled with a simple on/off switch.
Going forward, I will convert some of these to a dimmer, so that some will be on/off, some will be on dimmer.
You cannot locally control the dim level with this switch.
So, this is what I understand:
You can dim the light w/ zwave controller or the dimmer on the wall
It would make sense, if you couldn’t use a physical dimmer with this… but then, what’s the point of this? If I have wave dimmable, but can’t physically dim, this is really a limited use product, right?
Sorry for not being more clear. It is confusing, especially when using ambigous names to refer to two different devices.
[quote=“johnes, post:5, topic:181763”]So, this is what I understand:
You can dim the light w/ zwave controller or the dimmer on the wall[/quote]
No!
You cannot use a standard wall mount dimmer switch of any kind to locally control the Aeotec dimmer module.
You can use a momentary wall switch to locally control the Aeotec dimmer module. Holding the momentary switch down causes the Aeotec dim level to ramp up or down to your desired dim level.
You can use a standard On/Off wall switch to activate the Aeotec dimmer. It will turn the dimmer On and Off, but it will not allow you to locally control the dim level. It is On/Off only. You would use a Z-Wave controller, like Vera, to adjust the dim level.
Think I might be understanding this...
So it seems I just need to look for a dimmer with electronic dimmability, something like the Linear WD500Z?
Replacing the wall switch with a Z-Wave dimmer switch like the WD500Z will allow dim level control by both the wall switch and the Z-Wave controller.
