I want to set the threshold change in temperature to a lower value (default is 2.0?C). Device is USB powered. Setting the parameter 40 (enable/disable the selective reporting) to 1 is working fine. But If I want to change the parameter 41 it always says “Failed at: Setting user configuration”. So I’ve tried to read the value of parameter 41: 1310976 (hex?). Converted from hex to dec this results in 140100. According to the manual this should be 1401 ?!?
I have tried setting …
- 1310976 (4 byte dec) → no error message, seems to work fine
- 131328 (4 byte dec (-> 020100 for 0.2?C?)) → Failed at: Setting user configuration
- 20 (4 byte dec) → Failed at: Setting user configuration
- 5121 (4 byte dec (-> 1401 hex)) → Failed at: Setting user configuration
What else can I try?
I have another Multisensor (battery powered) with the following values:
Parameter 40: 0
Parameter 41: 5121 (-> 1401 hex)
