@signalgod, can you tell us how you placed your sensor into “wake” Mode and what LED observations that indicated a successful wake mode? also I notice that the colors on the LED change the longer (10 sec) that you hold down the motion sensor inclusion button (I seem to get to red that flashes around 8 seconds and gets faster). any help would be greatly appreciated. Mike
[glow=red,2,300]Update:[/glow] Just read a review in Amazon.com where someone made mention of errors documented within the manual in particular; “The directions for waking up the device also appear to be incorrect. I was unable to wakeup the device following the directions, and the light cycled through a couple different colors as I held the button, suggesting I was accessing some other functionality the manual didn’t describe at all. (This was also the case for the previous Gen5 multi-sensor. The manual said “hold for 3 seconds” to wakeup when in fact you needed to press three times.)”.
[glow=red,2,300]Update II:[/glow] Found two other sources that suggest the following;
[ol][li]Web Page "Procedure to Wake-Up: Pressing the Z-Wave button once will trigger sending the Wake up notification command. If press and hold the Z-Wave button for 3 seconds, the MultiSensor will wake up for 10 minutes." [/li]
[li]Complete Aeotect Multisensor 6 manual 21 pages (tried to attached but too big) has everything one would want to know about the sensor including various table describing library and command classes, All functions of each trigger, association Command Class, and Configuration Set Command Class parameters.
Waking up your MultiSensor.
If your MultiSensor is battery powered, you will need to ensure that it is active when configuring it. To do this, press the Action Button once, which will trigger to send out a wake up notification command. If you want it to wake up for 10 minutes, to do this, press and hold its Action Button for 3 seconds and then release it. Your MultiSensor?s (orange) LED will fast blink for 10 minutes to indicate that it is active. When you are done configuring or communicating with your MultiSensor, you can put it back into sleep mode to conserve battery power. To do this, press and hold its Action button for 3 seconds and then release it. Your MultiSensor?s LED should now be off to indicate that it is asleep."[/li][/ol]
Can anyone confirm or deny this information. When I pressed the inclusion button three times the LED came on with a steady “BLUE” light, when I press the inclusion button for 3 seconds it changes color to ~orange but did not flash and/or stayed on for 10 minutes. Still haven’t got pass the looping purge…
[quote=“signalgod, post:71, topic:187238”]I’ve followed Tom’s directions on the VeraEdge and have: Temp, Humidity, Light, and Tamper protection (but not motion it seems). I did have to try it 3 times, but realized that after the first reboot, I needed to constantly place the MultiSensor6 back into ‘wake’ mode to prevent the “purging association loops”. Each time the banner would show errors (by turning red), I would place the sensor back into “wake” mode and the banner would turn blue and the VeraEdge would continue whatever it was doing. It took a while.
I’m new to this. Could someone please explain to me why it is so difficult to write an “app” for this particular device so that we can have all the functions? UV would be awesome.[/quote]
