Hello,
I installed an Aeotec micro smart switch 2e in a lighting circuit. Two three way switches control a contactor which engergizes the lighting circuit. The switches and contactor are on a different branch circuit than the lights the contactor controls.
First switch box has incoming power (LNG), three wire w G to the second switch box, and outgoing switched power to the contactor (LNG).
I installed the smart switch in the first box. Line N, Line power, and contactor power to smart switch. The two three way switches were connected to one another (Red /Black). First low voltage wire from the smart switch went to the first switch common terminal and the other low voltage wire from the smart switch went to the second switch common terminal.
When I press the smart switch button, the contactor/light works properly (it turns on and off). However neither three way switch has any effect. I cycled thru all three modes (2 way, push button, 3 way) with no effect. I thought the inter switch run might be too long for the low voltage terminals so I tested with the second switch six inches from the first. Same result.
I then disconnected both three way switches and connected a simple on/off switch to the smart switch. I reset the smart switch. Same issue. The smart switch button works to turn the lights on/off but the 2 way switch had no effect.
Please help.
