I have a Schlage BE469 deadbolt about 30 feet away from the controller. The signal path goes through two walls.
The battery life has been fairly abysmal (drops to 50% within a month; all my other identical deadbolt locks last 6+ months), so I surmised that maybe the signal strength was weak, so I plugged in an Aeotec Extender between the devices (actually, about 5 feet from the deadbolt, so much closer) and paired it with the controller.
It didn’t resolve the battery issue, so I did some digging in the various Advanced settings and as far as I can tell, the deadbolt is still associating directly with the controller (the id_parent is still 1), even after several months, multiple unpair/pair processes, several “update neighbor nodes,” etc.
My question is: how do I see which node my deadbolt is connected to and, if it isn’t the extender, how can I guide the deadbolt to connect to it instead of bypassing it and reaching all the way to the controller?
This seems like a case where a nightly network heal might be useful, except it seems that Vera did away with that in a firmware update awhile back, and now there’s no way to trigger one…
If you haven’t turned off polling of the lock in Vera, or set it much higher than the default 60 seconds, anything else you do is not going to have a big impact. Vera will mash the batteries polling at the default interval (and the more complex secure channel interaction also seems to make the system less stable/more susceptible to deadlocks and reloads).
I have found Schlage’s (particularly older ones) just don’t like to place nice with most other devices as a pass through, they can be tricky (if not impossble) to get them to use a repeater device, One I had Schlages just wouldn’t function at all if it was running through a repeater, so you might be out of luck depending on the age of your lock. And unfortunately you can’t update the firmware on them either.
I think you can do a Update Neighbor Nodes in the Device Option table of the device to try the heal the mesh for the lock to see if it will pick up neighboring nodes, but I have found Schlages are just happiest when close to the Vera.
Also keep in mind that the lock is probably an S2 device, and if the repeater is not, I don’t think that will work. So if your Aeotec Extender is a 6 or earlier, that could be the reason.
