Hi all,
I just buy a new Aeotec Door/Window Sensor 7 to integrate with my Vera Controller (1.7.4969 (7.31)) and when I pair the device it shows as two devices:
GenericIO
MotionSensor
I have other Aeotec Door/Windows Sensor 6 that show up as DoorSensor.
I tried to edit the GenericIO and modified in vera to look like a DoorSensor but it doesn’t work. Also If I open the window, nothing changed on the Vera controller web page and I not able to notify when the window is open.
If the parent device is still not working then as a door / window sensor and does not trip when you open the door / window and does not untrip when you close the door / window.
I would also modify the child device (Motion Sensor) the same to be a door sensor. Does that child device work and trip / untrip ?
Many thanks cw-kid, following your instructions the parent is working. I did the same for the child device but it does not work adequately some time appear tripped some time not. I do not know what it is expected that the child must do/show.
Nevertheless with the parent device it is ok to me.
I using the digital entry of the device (changing parameter 1) and it is working well.
