Aeotec Door/Window Sensor 7 - How do you set Parameter 1?
I have an Aeotec Door/Window Sensor 7 setup in my Vera Secure. I used this help here: Aeotec Door/Window Sensor 7 not working
It is operating using the standard magnet however it has an external contact sensor option I would like to use. According to the documentation here: https://aeotec.freshdesk.com/support/solutions/articles/6000223859 I need to set the Parameter 1: Operation Mode. If someone could help me find where I modify this in Vera it would be appreciated. I also believe I need to set it for normally closed somehow.
Thank You.
go to device setting/control and then device options , the setting are shown there, You can add new add new parameters by clicking add configuration setting
ElCid, thanks so much, working great !
