I’m using VeraPlus IU7 (7.0.17) and I connected in my zwave network a multisensor 6.
Everything OK but the temperature value is 76?C (the real temperature is around 22?C)
I tried to calibrate but Max +/- 10?C.
Any idea or suggestion?
thank a lot
Looks like it’s in degF
Normally the European multisensor should be in Celsius.
The US in Fahrenheit (also different frequency)
I did not find any options.
Solved
I changed the Unit Settings to Fahrenheit and then back to Celsius.
After 15/30 minutes the value was OK!!
thanks
The same problem and same solution!
