Aeon multi sensor false triggers INSIDE the house
I’ve seen that some users had problems with false triggering outside the house, and using batteries to power the device. But what I do not understand is that my Aeon 4in1 Sensor which is inside, in my kitchen, with a power adapter, has had 2 false triggering last night without any reasons, except maybe paranormal activity in my kitchen :o I have last firmware on my sensor.
Does anybody has the same problem with this sensor INSIDE the house?
Same problem here I’m afraid. Mine is mounted on the ceiling next to the stairs and triggers the lights on the landing and the lights upstairs, right outside the bedroom. I’ve seen lots of false triggers per night!
Gesendet von meinem GT-P3110 mit Tapatalk 4
So it will be difficult to integrate this sensor as a valid alarm system :frowning:
Read more about this sensor on the forum. False triggers are common for this device inside or outside.
Sent from my Nexus 5 using Tapatalk
I had lots of false triggers inside and outside. I sent them back, had them replaced, still the same issue. In the end i returned them and gone for Everspring. No problems since.
yes, I have an Everspring sensor, works great, but each 2 months needed to change the batteries… It could be geat having an everspring with a power adapter!
