I like to know how we get access to the infos from Aeon HEM… I can not figure out which setting I can use to get to total WATT and the KW…
Use the Multi Value control, link it to the HEM, and then select the right properties from the HEM to display in the control’s properties. KWh and KW are there.
Yup. After adding it, you will need to go back into the properties of the new item added and search for the 3 items which are currently listed as manufacturer, version and something else. Super easy to do.
It is working now… a little tricky to get the right variables… Homewave has been excellent for me so far… ![]()
