I have multiple Aeon Labs multi sensors spread around the house and, once I understood the actual process required to get all the readings in Vera Lite, I was quite happy with what I get.
I have one of the sensors that is outside the house, with a direct view on a wall at ~20’ that has an Evolve wall dimmer LRM-15 installed. The Wall dimmer’s favorite route is through device 0 with signal level 10, which I assume is a good signal straight to the VeraLite box.
Once the sensor was added to the network inside the house, I tried moving to its final location outside. For some reason, though, the signal cannot reach the network.
Loking at the advanced tab, I cannot see any routing information. I tried searching the web for answers (I googled, you know), but could not find a topic that discussed this precisely.
With a single device moved, is it possible to only heal that one? I was under the impression that “Update Neighbor Nodes” was some sort of localized heal that could be used for such devices that do not retransmit packets to other nodes.
yeah, you can ‘heal’ that single device. Just enter the device number wham you do the heal. It never hurts to do a full network heal, though. This is particularly true of you have relatively few devices.
Should you always let Vera reconfigure as well when you heal your device/network or can you deselect that option, i.e. will the device (Aeon in this case) get the new route info without a reconfiguration?
battery powered devices like this are typically less sensitive to the heal process because they are not capable of bridging devices. They are essentially dead ends on the mesh network. I would leave the nightly heal process as it is setup by default and perform a heal.
Then, review the report from the heal and look to see the quality of the connection to the sensor. That will tell you a lot, because vera will seek the best path to connect ti it.
Try that, and if you like, show us the results. At 20ft away, my experience tells me you are likely to have problems, particularly if you have walls separating the vera from the sensor.
I ran a manual heal yesterday (the automatic heal job don’t show any stars). The result is a little bit as I expected. The devices in the house have very good connection, the ones on 230V in the garage are ok while the battery operated ones outdoors have poor connection, including the Aeon. Though, the ones with 0 stars still work but I guess they communicate through other devices (can’t check this as the hoover function in the report doesn’t work).
Anyway, this can explain why my Aoen is a bit flaky. I think I should be sure communication works flawlessly before doing anything else. I think I should def connect the sensor to USB/230V for a start. But, step one whould be just to double check that my Z-wave settings are optimal. I’m running the default ones but maybe there are improvements to do? See screenshot below.
