Hello !
I’ve problem with Aeon Labs Micro Smart Energy Switch. I connected external button via proper slots mentioned in manual. Push button doesn’t make smart switch turn on. Have sb similar problems?
Hello !
Does the smart switch turn on/off when controlled through Vera?
Yes, but i thought that this external switch is designed to turn on/off micro switch. Furthermore i tried to turn it on/off my by making scene, including luup code - i do exacly as examples in luup codes about turning on/off switches.
In manual there is chapter about turning on/off and there is
Pressing the button on external (Wall) switch will be able be to toggle power flow (on/off) through the Smart Energy Switch
if you hold the push button in, do the lights turn on? aeon labs by default are set to toggle switch. push and hold the module button for 6 seconds and the red light will flash quickly. now it will support push button momentary switches
thanks it turns on and off but there is no update in dashboard until i poll it from settings tab
