Aeon-Labs HEM2 reporting to Mios
Hi there,
I had success installing my new Aeon-Labs HEM2.
But, although success, it also causes problems.
Before installing the HEM2, my Vera worked like a charm, but now it is becoming instable.
I want my HEM2 to report the current Watts as soon as the value changes more then 10 percent.
So I disabled the HEM2 Delta (setting Variable 3 to 0) and set the percentage for the whole unit and the clamp1 to 10 percent (Variable 8 and 9).
This works as I expected.
However, every now and then Vera becomes unresponsive, sometimes showing “Server Busy”.
Looking at the LuaUPnP.log I noticed the following errors:
01 08/20/11 16:12:11.696 RAServerSync::SyncSection ERR: Missing parameters for https://evt1.mios.com/sync_section.php?PK_AccessPoint=xxxxx&HW_Key=<encrypted_key>&SectionList=1,3,4&SectionID=3&SectionDesc= <0x402>
01 08/20/11 16:12:13.192 RAServerSync::SyncSection ERR: Missing parameters for https://evt1.mios.com/sync_section.php?PK_AccessPoint=xxxxx&HW_Key=<encrypted_key>&SectionList=1,3,4&SectionID=4&SectionDesc= <0x402>
Looking at my account at MIOS.com: Energy I see the accessPoint which also is in the error lines above.
Also the graph at MIOS is updating very often.
Does anybody know how to turn off reporting energy from the HEM2 to MIOS??
Or else, what parameters should I fill in where???
Any advice would be appreciated.
Thanks.
@snotneus,
i cant answer your question, so someone else will have to chip in there.
But i DO recommend removing your accespoint# and hardwarekey (HW_key) from your post!
  • Henk
@Henk,
Thanks, I did not realize!
