Aeon Labs Door/Window sensor and Schlage lock Battery Status
I have both of these devices setup and working. When I configure them there is an area "Fire warning event when battery is below” I can type a number in this box but, never get prompted to save it. Am I doing something wrong? Thanks,
There should be a save button on the upper right side of the web page … at least that is where it is on UI4.
There should be a save button on the upper right side of the web page ... at least that is where it is on UI4.
I do not have that option. If you are referring to the red save button that normally appears in the upper right when you are making normal changes… thanks,
I should have said “Red” … that should save your events.
When I setup my devices and edited their names I was prompted with the red save button on the upper right of the screen. When I edit either of the devices in question and type a percentage for the battery warning I am never prompted with the save button. If I change the name of the device I do get the red button. I tried entering a percentage for the battery and changing the name of the device but, it only saves the name of the device not the percentage i entered for the battery.
Same here, precentage for the battery warning is not saved and the red save button is not visible if I only change that field. (Vera2 UI5 and Everspring sensors)
I have the same problem…
Vera 3, UI5, You are running the latest version: 1.5.286 .
AEON Labs Door/Window Sensor
1.5.322 is latest version… might as well upgrade to this :slight_smile:
FYI…
I am running Vera 3, UI5, 1.5.322
thanks,
it sets default values automaticly . do these work and the battery empty message gets send ?
you could also try and add the value manually and set this to the desired percentage.
I doubt it. There were definitely similar issues with this in the past, and they may still be unresolved. (E.g., see this bug report.)
it sets default values automaticly . do these work and the battery empty message gets send ? you could also try and add the value manually and set this to the desired percentage.
I have tried setting the value’s manually and it does not work. It never prompts to save changes.
i experience the same with a lot of settings and plugins… donno whats wrong but it seems there is some bugs in the ui5 left … tried all browsers i could find… didnt make a difference…
they probably still need to implend it … its beta ui afterall…
its allways a good thing to report non-working stuff so people be able to look at it
i believe there is a update underway within the next weeks, might fix the issue you and others have :slight_smile:
