Aeon labs 4in1 (gen5/zwave plus) multisensor, does it work on UI5?
Does the new (gen5 / zwave plus) 4in1 multisensor from Aeon Labs work on a vera lite which is still running on UI5?
(i was looking for a outdoor sensor which reports temp and lux info, this sensor is suitable for outside and has these options and even more…)
I know that the ‘old’ 4in1 sensor works (because i got 1) on UI5, so i wanted to buy another one but only can find the new model ‘GEN5’ or Zwave plus version, the old version is out of stock everywhere in The Netherlands.
No one can tell me for sure if this new model works with UI5, it should work fine on UI7 but I don’t want to upgrade to UI7.
On UI7 a lot of plugins (which i use currently) are not compatible or do not exist for UI7, that is why I want to stay on UI5.
Who can tell me if this new 4in1 sensor works on UI5 or not?
[quote=“B3rt, post:1, topic:188051”]Does the new (gen5 / zwave plus) 4in1 multisensor from Aeon Labs work on a vera lite which is still running on UI5?
Who can tell me if this new 4in1 sensor works on UI5 or not?[/quote]
Hi Bart –
I don’t know the answer but the chances are that it will not… Think it is designed to use the new Z-wave series 500 chip (Zwave+). Believe you need the Vera Edge controller for that. Also, believe MCV has not be modifying UI5 to handle new z-wave device offerings.
Don
Don’t know the answer either but as Zwave Plus should be backwards compatible…it could work.
It does not work (tried it).
The sensor is reqonized as zwave device but cannot be configured as sensor.
I had to return it and was lucky to found an old version of this sensor which I now use.
[quote=“Don Diego, post:2, topic:188051”][quote=“B3rt, post:1, topic:188051”]Does the new (gen5 / zwave plus) 4in1 multisensor from Aeon Labs work on a vera lite which is still running on UI5?
Hi Bart –
Don[/quote]
As a workaround, you might see if it’s working with the wink hub–I’m not interested in moving to UI7 yet either, but an interested in some of the Zwave plus devices. This was suggested to me as an alternative.
[quote=“tb001, post:5, topic:188051”][quote=“Don Diego, post:2, topic:188051”][quote=“B3rt, post:1, topic:188051”]Does the new (gen5 / zwave plus) 4in1 multisensor from Aeon Labs work on a vera lite which is still running on UI5?
Hi Bart –
Don[/quote]
As a workaround, you might see if it’s working with the wink hub–I’m not interested in moving to UI7 yet either, but an interested in some of the Zwave plus devices. This was suggested to me as an alternative.[/quote]
Hi
 Please let us know if the wink hub works itch this device.
   Don
what is a ‘wink hub’?
have no idea what this means…
I had the gen5 and have the newest one, smaller unit, working in UI5. It is with the unsupported 672 build.
Hi!
What settings you have made to make it works?
I pass all steps of instruction below (thanks to Aeotec support) but sensor does not detect motion. I use Vera Lite UI5 and AEO_EZW074
  1. Add as “Generic Device”
    1.1 If Vera fails to send security node, then unpair the device and try again
  2. Go to “Advanced” under the Generic Sensor
  3. Device type changed to “urn:schemas-micasaverde-com:device:MotionSensor:1”
    Device file changed to “D_MotionSensor1.xml”
  4. The Sensor May or May not disappear, if it disappears then unpair or factory reset the device and return to step 1.
  5. Go to “Device Options” under the Generic Sensor
  6. Click on “Add new configuration”
  7. Variable = 5
  8. Size = 1 byte dec
  9. Desired Value = 2
  10. Before saving this, wake up the Multisensor momentarily by pressing and holding down the button and then click the save button on the top right side of the UI5 interface.
hi,
are you able to make z wave plus sensor to work on UI5? vera support tried and it didn’t work so they said me to change to UI7, I migrated and its nightmare, basic thermostat is not working (web UI is work but iOS app it will not display fan NO/OFF or even you can not increase/decrease the temperature ), if it works then let me know
Thanks in advance
Thanks,
Dip
