This is tested on Vera 2 running UI5.
Summary:
Recommend HEM powered by USB, not battery and then configure in Vera also:
- Upgrade firmware to 3.67
- as USB powered (not battery)
- disable deltas
- set a single report group
- send all values every 20 seconds
- Optional method to hide _ Generic IO
- Optional method to calibrate
How to configure HEM in VERA:
Firmware version 3.67 is posted on wiki, but not on Aeon’s own web site. Download link can be found at:
[url=http://wiki.micasaverde.com/index.php/Aeon_HomeEnergyMonitor]http://wiki.micasaverde.com/index.php/Aeon_HomeEnergyMonitor[/url]
Click the main device, settings, Device options, Add configuration settings (one for every line shown below):
Variable / Data Size / Desired Value (see screen shot)
3 1bD 0 (disable deltas)
101 4bD 0 (report group 1 disabled)
103 4bD 6926 (report group 3 all settings)
111 4bD 720 (report group 1 every 720 seconds)
113 4bD 20 (report group 3 every 20 seconds)
20 mon (verify is 1 = USB power)
12 mon (verify is 0 = battery related)
102 mon (verify is 0 report group 2 disabled)
112 mon (verify is 720 report group 2 interval)
_ Generic IO can be hidden as follows:
Click Apps, Develop Apps, Test Luup script (insert the device ID at the end of the item you want to hide. In this case 47)
luup.attr_set("invisible", "1", 47)
How to calibrate KWH…
Feb 23
Vera 235.2970 KWH
Meter 4991 KWH
Feb 26
Vera 272.6540 KWH
Meter 5021 KWH
Delta
Vera 37.357 KWH
Meter 30 KWH
Approx 24% too high (37.357 / 30)
120 /1.24 = 96.36
Change Voltage from 120 to 97, i.e. Device option Variable 1, update from 120 to 97 (see screenshot)
You should play with this in order to find what works for you. You will see the calibration using this method works in principle! I am current(ly LOL) set to 95 and have not checked the values in a couple months.
Related materials:
Configuring Register 101-103 for HEM Gen 1 and Gen 2 [url=http://forum.micasaverde.com/index.php?action=dlattach;topic=3366.0;attach=21720;image]http://forum.micasaverde.com/index.php?action=dlattach;topic=3366.0;attach=21720;image[/url]
Credit to Hexasoarus for the splaining and the work on the Excel file: [url=http://forum.micasaverde.com/index.php/topic,3366.msg213636.html#msg213636]http://forum.micasaverde.com/index.php/topic,3366.msg213636.html#msg213636[/url]
Binary to Decimal to Hexadecimal Converter: [url=https://www.mathsisfun.com/binary-decimal-hexadecimal-converter.html]Binary/Decimal/Hexadecimal Converter
Useful link. Most of the values described are incorrect IMO, hence the importance of using the chart and binary converter. [url=http://forum.micasaverde.com/index.php/topic,3366.msg94937.html#msg94937]http://forum.micasaverde.com/index.php/topic,3366.msg94937.html#msg94937[/url]
