I have set up an Aeon DW Sensor in my VeraLite and have noticed that if a door is rapidly opened/closed the sensor seems to report the wrong status.
Eg.
Open the door - Vera shows open
Close the door - Vera shows closed
Open the door again within 15 seconds - Vera still shows at as closed.
The Vera doesn’t seem to register another open event until 15 seconds after the first close event.
Is there a way to reduce or remove the 15 second timer before it registers another event?
