Hello,
Has anybody detected the Problem with the “Tripped” variable in Aeon DSB29 (second edit) Door/Window sensor.
The Variable “Tripped” stays in “0” IF you do the following in less than 10 seconds:
Open-Close-Open. So the Controller have a mistake in the variable.
The Vera doesn?t receive the last open status, or the Sensor doesn?t send it.
This is a problem with the compatibility between the device and the VERA controller running Ui7 last firmware.
This sensor is in the list of devices to add in UI7. Please delete it from this list if it doesn?t run.
