Advanced Configuration - What is Root password for MCV???
  1. Click Advanced on Dashboard
  2. Click Net & WIFI
  3. Click Advanced Configuration Link
Redirects to here:
/cgi-bin/webif/info.sh
username: root (filled in)
what is root password?
Thanks for your help.
How do I change the Root password? Thanks
I’m assuming SSH into device? Please advice.
Have you tried the WiFi password from the sticker on the bottom of your Vera?
Yep. I just searched the post - that worked. Thanks oTi.
I also want to login in the advanced mode, because i need to set username and password to restrict access from outside.
However, i have a Vera Lite module and on the sticker no such password is mentioned?
Can anyone help me?
If you go to Setup → Backup, you can download a (latest) backup stored on MCV’s servers. If you extract the archive and navigate to the etc directory, you’ll find a file called cmh.conf which is a text file. In it you’ll find a string like ‘Password=bladiebla’. That password is your root password.
Then just ssh root@<vera’s ip> and enter the password…
Thanks Quinten, that worked ;D
What program is used to extract the backup?
See previous threads
http://forum.micasaverde.com/index.php/topic,7110.msg45228.html#msg45228
The above contains an app by @futzle to return the root password.
http://forum.micasaverde.com/index.php/topic,13204.msg98110.html#msg98110
