Hello !
I am trying add my ir devices to vera, but I am using the channel Zero of sqblaster to turn on a device. in the list in vera do not appears the channel zero, only 1, 2,3, and 4 and sqblaster plugin.
how can I associate my device if that is using channel zero ?
I have 5 options, 4 led channels and a sq blaster plugin. Could that be it ? I dont know if that does anything but if you havent tried might be worth giving it a go
The “main” or parent device (SQBlaster) is an IR Transmitter, along with the Aux 1…4 devices that are created, and all can be selected in the drop downs when attaching an IR Device.
In the screenshots, this shows as “SQBlaster +”, and the 4x extras are labeled “IR Aux Channel [1234]” but it’s name will be dependent upon how you’ve renamed it in your system.
