I have had some success getting Insteon devices added in to vera, but the inclusion process only seems to work 20% of the time.
When adding a switch on Step 2 “Pair your device” It states
- Press the ‘Set’ Button on the INSTEON device to add it to the INSTEON database and the new detected INSTEON device will appear.
OR - If you know the INSTEON Device ID, enter the ID in the space below. Then click the ‘Add Device’ Button.
Number 2 never seems to work. Entering the address in the format 22.3b.bb results in no change or feedback that anything was added. Even if I have already gone through the inclusion process manually.
I had all of my switches added at one point, then one day they all went away in the UI. I know the support for Insteon is very thin here, and my best course of action is to dump Insteon and switch to zWave or Zigbee. But I have a number of these legacy devices, and can’t really swap them out all at once!
