Adddevice Tab Missing
I have a VeraLite with the RFXCOM RFXtrx433 and a handful of LightwaveRF switches and sockets - trying to connect them manually but the add device tab is missing in the controller options. I’m guessing I’ve done something wrong. Any ideas?
I’ve attached a screenshot of the bit where the tab should be.
Just scrill down…
There’s supposed to be a third tab next to settings and advanced. If I scroll down there is no option for adding any devices.
http://www.vesternet.com/resources/application-notes/apnt-47 shows the tab.
I’ve just checked this.
When I created the guide, I used an older version of the plugin.
If you scroll down to the bottom of the settings tab you should find the same ‘Remote ID’, ‘Unit Code’ and Add LWRF Dimmer buttons as shown in the screenshots.
I’ll update my plugin tomorrow and update the guide to show the current version of the plugin.
