Hi.
I bought a Secure SIR321 last week to control a Solar Panel with a Thermistor whitch I can get temperature.
Then I connected the SIR321 to my Vera Edge and I can on/off electricity to heat the water.
Too, I want to know temperature of thermistor that It is in CurrentTemperature varible. For that, I create a virtual temperature device:
Apps->Develop apps->Create device
Description: Vitual temperature
Upnp Device Filename: D_TemperatureSensor1.xml
Upnp Implementation Filename: S_TemperatureSensor1.xml
And push Create Device. Then Reload Engine. After that you will see a new Device.
Now you need to create a variable, go to Devices->Virtual temperature->Advanced Tab->New Service and set:
New service: urn:upnp-org:serviceId:TemperatureSensor1
New variable: CurrentTemperature
New value: 10
And push Add and Reload Engine. After that you will see a temperature with 10?.
Now you need to refresh Variable every 30 minutes (or what you want)
Go to Scenes and Create one every 30 minutes and in Luup code wirte:
[code]local temperatura = luup.variable_get(āurn:upnp-org:serviceId:TemperatureSensor1ā, āCurrentTemperatureā, 20)
luup.variable_set(āurn:upnp-org:serviceId:TemperatureSensor1ā, āCurrentTemperatureā, temperatura,22)
return true
[/code]
Where 20 is ID from SIR321 and 22 is ID from Virtual temperature.
Bye.
