Add USB WiFi Adapter To Vera Lite ?
Is it possible to add a USB wifi adapter to the Vera Lite so that it could talk to a wireless router ?
Do you mean like this?
No, not exactly like that. What I would like to do is just plug in a USB Wireless Adapter into the VeraLite and then have it configured to be able to talk to a wireless access point.
By the way, I have indeed used repeaters (range extenders) to accomplish this but if I can go the USB adapter route, then I eliminate the repeater (which is a pita) and I eliminate the power receptacle requirement.
It’s likely very possible to get Vera to use a USB wireless adapter but you will need to be familiar with Linux, able to configure wireless and network adapters under Linux, and accept that firmware updates will wipe out your configurations.
Possible, yes. Practical, much less so. Plug and play, no way.
Yes, I am familiar with Linux but Linux networking not so much. As far as the firmware wiping out the config, well, I guess a script could be ran after any update.
What I really want is that new Vera model that has the wifi client built-in!
[quote=“PaulMcT, post:5, topic:176140”]Yes, I am familiar with Linux but Linux networking not so much. As far as the firmware wiping out the config, well, I guess a script could be ran after any update.
What I really want is that new Vera model that has the wifi client built-in![/quote]
That would be vera3.
