"Add room in section" reset after each "Add room" button click
Adding multiple rooms requires unnecessary actions to set the “Section” (floor) in the “Add room in section” combobox since it resets to the first item every time you click “Add Room”.
It is likely people will be entering multiple rooms for the same floor/section one after the other and resetting the selection makes this task more difficult and causes entry errors.
Consolidated this into bug report: http://bugs.micasaverde.com/view.php?id=178
