Hi
Is it possible to use a usd hub with the Vera lite so I can connect more than 1 USB driven devices e.g 2x Current Cost Monitors?
Hi
Yes, is perfectly fine. You may want to use a powered usb hub, but other than that, it should support most (if not all) usb hubs.
A powered USB hub is highly recommend
